mtd
- Sep 22, 2010
- 230
- 186
- 43
- Location
- melbourne,VIC
- VE S1 Calais V V8
Hey all,
Due to a water leak (which I am yet to diagnose whether 1 or multiple locations) I'm considering temporarily removing the front seats so I can deal with the leak properly. Underlay is frecken drenched. Bugger! I won't rave re the Melbourne weather.
In another thread it was stated to ensure the battery was disconnected because of the airbags. I'm gonna assume its not just because you have to disconnect the seat electrics. i.e. Just being careful...
Gonna ask a silly question - why exactly is this required? At a wild guess i'm thinking it would be because of some interference with the checks that are carried out on startup with the bag sensors? Maybe it requires a reset if this happens - heard this elsewhere I think...?
So, follow this process (please, by all means, correct anything wrong here):
Removal:
- Slide seat forward - undo rear bolts
- disconnect battery
- Tilt seat forward, release electrics and remove seat by tilting/lifting (think it has no bolts front?)
Installation:
- Sit seat from front to back (seems to be a 'claw' fitting front - is that right?)
- Tilt seat and re-connect electrics (no connection to battery yet)
- Redo back bolts.
- Reconnect battery.
- Test
Anything wrong here? Anything I'm missing or gotcha's? Won't have to get the airbag sensor stuff reset will I?
Thanks all. Cheers
Removal:
Installation:
- Redo back bolts.
- Test
Thanks all. Cheers
