mtd
- Sep 22, 2010
- 230
- 185
- 43
- Location
- melbourne,VIC
- VE S1 Calais V V8
I rub silicone paste into mine to keep them supple and full. Like my lips.
Cheers,
Cheers,
Done a bit more investigation. Guess what, its raining so cannot confirm leak below just yet, and getting too dark.
Fu got me thinking when he asked about cracks in the weather strip channel seam etc. Took off the weather strip again to have another look. No big 'traditional' cracks, but right where I suspect the leak is coming in the paint has flaked away (arrow with 'culprit') and there does seem to be a gap (that's a small rock wedged under the channel plate).
It might be a bit of confirmation bias on my part, but as this tends to only drip inside on a heavy rain event - and the 'culprit' area is at the lowest point (the channel slopes up slightly towards the windscreen, can be seen in pic) then this is starting to make sense. It would pool there and be continually replenished. The bottom line is, is water getting through??????
That said, I could be on enrirely the wrong track - time will tell.
Other small pic is a close-up. What do you reckon?
Think my arrow descriptions might be a bit wrong in hindsight, is that white stuff primer or sealant?
I'm in the middle of pulling out trim and will continue tomorrow.
If i find this is, in fact, a leak. What should I seal it with. Some type of Sika sealant?
Faark yeah.Done a bit more investigation. Guess what, its raining so cannot confirm leak below just yet, and getting too dark.
