Front end:
VB - VN Radius Rods
VB - VN Lower Control Arms
VN V8 Sway Bar
VN V8 Struts
VN - VS V8 Calipers
VN - VP-VQ V8 Rotors
VB - VP-VQ V8 Springs
VB - VP Strut Bearing Mounts
VB - VP-VQ V8 Ball joints
VN - VP V8 Tie rod ends
VN V8 Steering rack
VL Intermediate Steering shaft
VN VQ or VP 1" Master Cylinder and Booster
Just corrected some of your front parts list to avoid confusion as vs parts will not work without further changes.
And just a note my conversion would pass any state in Australia no problems at all as Valve timing and induction is not modified, the evaporative emission control devices are fitted and operational, the noise emitted from the exhaust is in accordance to road traffic act 1999 Div3, standard injectors and management is fitted, the brake master cylinder and rear calipers are compatible with the disc/disc combination, the correct balance front / rear is achieved, and no sharp objects in or outside the vehicle.
I also opted for the modern upgrade of instruments with original gauge faces done by castle auto electrics and what a heap of ****! it cost me $800 and if i had of know what they do i would done it myself and done a much better job of it and as it was i had to rewire the gauge cluster because they had it shorting out and thus it never worked. the tach was supposed to be modified to work with the vs signal but to this day it still doesn't work.
