Danny-VE
- Aug 13, 2018
- 4
- 0
- 1
- Age
- 38
- Location
- Adelaide
- 2011 Copmmodore VE Series II 3.0L V6
Hello everyone,
Have a bit of a problem with a continuous P0300 error code and the check engine notification with no other code.
Car is a 2011 VE 3.0L Omega Sedan.
Here is the tricky part:
Initially I believed that it was from the timing chain as the check engine light came up under multiple conditions. I got that replaced about 2 months ago.
Most of the check engine problems have resolved except under one particular circumstance, when engine braking.
As I am going down the freeway, I move to sequential mode, I place the car in 3rd gear and let it maintain the speed, with RPM sitting at about 3000 all of the sudden check engine light comes on, Traction Control Off, keeps beeping like crazy until I put it in normal gear and accelerate a bit and then it goes away. No change in feeling or drive.
Check ECU and get P0300.
Mechanics did the simple things like new spark plugs, cleaned valves, timing chain... but I am wondering if there could be anything else that they have not checked that could affect the car only in the above circumstances.
What I have noticed that has developed:
1. Around the 2500-3000 RPM mark I can head a sound coming from the engine that I would compare it to something like two plastic geared wheels slipping on each other or like a chain slipping on a geared wheel. Below those RPM is disappears and above the engine sound could be louder.
2. Starting the engine, it hold a high Idle for about 15 -20 seconds which I find a bit long for a modern car. Would that be normal?
3. Very strong hissing sound, pointing to a vacuum leak but I know that it would affect mostly the idle, nothing to do with high RPM.
Anyone has any idea what I can check next?
Any information if highly appreciated.
