Where did you get the chains from and what are the codes you're seeing? Underpowered?
Ok It was some years ago. 2 or 3 years. My son owns the car and drives it all over the state NSW. The error code came up immediately after replacing the chains. The OBD11 has always cleared the errors (8 and 9 and 17 and 18 and 19 all preceded with P00 as I remember).
Sometimes and more frequently these days the car goes into limp mode. This is mostly fixed by clearing the error codes but sometimes he removes the negative battery terminal for 10 minutes. He is getting sick and tired of having to do this.
I took the car to Col Crawfords at Brookvale a year or so ago.....waste of time and money....They did NOTHING
When the car is not signalling an error.....it goes along perfectly from idle to whatever the revs are at 120km/h.
I bought the Cloyes chain kit from a distributor in Melbourne and replaced all idlers, guiders and tensioners and used cam lockers. I did not replace any sensors.
Really I just want someone to say that the ECU plug in management tool will tell the service technician more than an OBD11. But I havent found anyone prepared to say that to me.
