SS Manual
Hi all,
Have had an issue after pulling up at home yesterday in my ute, thermo fan was still running after I turned ignition off.... Couldn't work out the prob so undid the battery. Went back to start it this morning, after re-attaching the battery terminal the fan came on again instantly.
Had a read through several forums to try and diagnose the problem. Most posts were saying it was a relay that needed replacing...
Went and identified the relay that when pulled out would shut down the fan and drove down to Supercheap to pick up another one ( It's the 5 lug engine cooling fan relay 1 in the owners handbook) . Upon installing the new relay the problem hasn't gone away...
I suspect it could be something else, perhaps a dodgy wire somewhere?, coolant thermostat?
Has this happened to anyone else and did you find an answer before booking it in for some professional help?
Regards,
SS Manual.
Regards,
SS Manual.
