- Apr 15, 2006
- 22,756
- 20,864
- 113
- Location
- Sth Auck, NZ
- HSV VS Senator, VX Calais II L67
IF it's contamination the filter should help. If it's bearing you should be able to feel it.
IF the bearing are bad enough to cause seal failure you would probably hear the bearings with the engine running and you would most definitely feel it when turning the pump by hand. Waterpumps have 2 bearings set some distance apart in the housing, for there to be enough run out of the shaft because of bearing wear you would definitely feel it turning the pump by hand, if on the other hand the bearing assembly wasn't pressed straight into the housing then the seal is doomed before it ever left the pump factory.
