Lucky you I had a leaking bolt just yesterday that needed resealing.
Trevor this is for VT, VR pulley has no dowels. The pulley was running flat, regardless of the shim. I have removed it anyway.His the video I too was confused but once i seen the runout I removed it..
And this is why the bolts on water pumps end up with stretched threads, which makes the bolts leak even more.The gasket will seal the bolt holes then there's the coolant that will seep past the threads but if you tighten the bolts up enough the alloy will seal to the bolt washer.
I just did a set of valley gaskets on a ecotec today I torqued the intake to head bolts but thats it every other bolt was done with feel.
But I guess thats not feasible for most as it takes years of experience to get to that point. So you keep sealing your bolts I'll keep using my method.
I've installed more helicoils than you've done up bolts. I have $3000 of taps, dies, tap wrenches and heli coil kits.And this is why the bolts on water pumps end up with stretched threads, which makes the bolts leak even more.
