bigge pickup also allows for easier ingestion of air round corners and under heavy braking and acceleration the pickup was made smaller to stop this from happening its not got that small bulb pickup for no reason its so it dont suck air.ecotec has no problems pumping 100psi cold oil pressure at idle and over 50 hot idle its plenty enough
All it does is vent oil vapour into the plenum.
Oil + Petrol + Boost + RPM = Detonation.
Made an aluminium plug to block off the PCV port only because Delcowizzid made me
