Underdrive pulley kit
pjdm1980
Shut up Jr I'm thinkin!
Geelong, Victoria
E1 GTS BUILD NO# 007, GQ Patrol.
I did have some problems with short trips but it may have been the battery, I've since replaced it with a yellow top and have had no issues. It charges at 14.0V which I'm told is a bit low.
nickb1993
sydney
ve sv6 ute
How much did u pay for your yellow top optima?
And yeah its suppose to be about 14.4 as a standard across most makes of cars but 14 is dtill plenty
pjdm1980
Geelong, Victoria
nickb1993
sydney
ve sv6 ute
And that fits straight in where the standard battery goes?
pjdm1980
Geelong, Victoria
I had to bend a wire on a terminal, move a small fuse box and use the spacer that came with the battery. It was a pretty easy job.
Diesel_junkie
New South Wales
VE SS
Not worth the potential head aches complete wank factor.
Sent from my GT-I9300T using Tapatalk 2
Potta9
33
Camden
Ve r8 , B2600
100% agreed
After going back to standard on mine my engine temps dropped by approx 7deg across the board. I watch my gauges like a hawk so knew straightaway.
GKW
Donating Member
2008 VE SSV & 1999 VT SS SII
25% U/D on my cammed L98 and no issues with temp, or voltage / charging, but I've heard similar comments from others too, so not sure why an U/D does or dosn't have this affect from car (talking VE) to another.
ADR 40
58
South Oz
VZ Lumina..... VEII Equipe Sportswagon
Underdrive kit has been on my VZ for two and half years and travelled a touch over 85,000km, had no problems with it just a new belt change for peace of mind.
(I should point out my mileages covered are in rural-remote areas with around 85% use at highway speeds.)
Another with a BF XR6 Turbo clocked just over 35k with the kit with a mixture of rural & city driving.... same deal no problems. (I could add a couple of VE’s, BA’s, and a Territory to that list)
Apart from a couple of blokes having an upgraded exhaust system, all of our cars are stock sixes.
Not sure why others had problems with the kit, but I reckon contacting that bloke at Mace Engineering would have an answer.
