Anthony .
- Apr 5, 2022
- 463
- 297
- 63
- Age
- 20
- Location
- NSW
- 1994 VR V6 Executive
Hi all,
I am planning to give my VE SV6 an engine flush using Penrite oil flush solution.
Like mentioned in other posts, car has 207xxx on the odometer.
I plan to get her as clean and running smooth as possible.
Is the oil pickup located on top of the sump? If so, how should I go about cleaning it as best as possible?
I also plan on running some injector cleaner through the engine. Do you recommend doing this after the oil replacement, or before the oil replacement, for best results?
