Jesterarts
Your freedom ends where mine begins
- Nov 22, 2005
- 3,817
- 105
- 48
- Age
- 38
- Location
- Victoria
- 2010 Nissan X-Trail ST-L
By the way, I found the thread where everyone was telling me NOT to use sand paper on rotors.
http://forums.justcommodores.com.au/vt-vx-holden-commodore-1997-2002/185124-brakes-question.html
Just to confirm, one if the sponsors on here who has a wealth of experience and have proven time and time again also agreed its a bad idea to sand rotor. I would like to know what expertise the people who are sayong it is fine to sand have?
Also, the advice the OP of this thread gave in the other thread was to sand rotors AND pads to eliminate squeaking. As described in the other thread this is dangerous as any pad material that has bedded to the rotor surface will be removed and next time the driver goes for the brakes they will not perform as as they dis previous to sanding them.
Since we all know that its the friction of the brake pad on the bedded pad material on the rotor that stops the car rather than pad on rotor metal. Thus, why we bed brakes when rotors or pads are changed. I'm assuming all the experts in this thread are keeping up this time.
And just to confirm what I mean by dangerous; doing something to the vehicle that will have a negative effect on its performance compares to what the driver is used to and expects.
Finally, I am assuming that the benefit some of you are putting forward of sanding brakea is to remove the old bedded material and aid bedding.
Two issues with this;
One, if you put new pads in they can be bedded in without sanding. So why bother?
Two, using sand paper causes groves and ridges in the surface on the surface of the rotor. It becomes course. This means that in order to bed properly, the pad material has to fill in the groves and wear down the ridges until the braking material is evenly layered on the rotor surface. Until that time, braking performance will not be at 100%.
To be clear... the objective of any disc machining or sanding if you sill is to SMOOTH the surface as much as possible rather than to make is course. Thus, sanding them to "roughen up brake rotors" is doing the opposite of what the goal should be.
At the end of the day, all the above probably won't have affect on the average driver as we rarely ask our brakes to put out 100% of their potential. Pulling up at the lights you won't notice the car takes an extra metre or two pulling up as you just apply 20% braking force instead of 15%.
But you will notice when you need to do an emergency brake and instead of scaring the crap out of the idiot pedestrian who ran out on the road, stopping only inches from them and pulling up 2m past the point you hit them.
Small difference in the equasion variables, big difference in result.
