ben315vz
Donating Member
- May 11, 2011
- 1,466
- 22
- 38
- Age
- 32
- Location
- Tamborine Mountain, QLD
- '05 Holden VZ Calais V8
Problem is where I work, they have set the compressor for truck wheels, to remove and re fit the wheel nuts. So when you use the rattle gun on cars, you have to be careful not to go too far and snap the studs. We have also had problems where customers come back and complain because they have had a flat tyre and were not able to undo the wheel nuts because they were too tight. That is another reason that I think it is a good idea to torque them to the correct setting. And also lock nuts, I have never used a rattle gun to undo or tighten a lock nut, but the apprentice where I work is that lazy that he has done them up with the rattle gun and ended up rounding the nut or the socket. Another customer had a VS SS Ute with lock nuts, he got a puncture and couldn't remove the lock nut because the socket was rounded, he ended up calling RACV, we ended up having to hammer an old socket on it to get it off.
