WaBally
- May 28, 2023
- 1
- 0
- 1
- Age
- 56
- Location
- Western Australia
- VZ commodore
Hi
hoping someone here may have had the same problem and can she some light my way.
Car is in limp mode. Codes are the P0700 mil request error code. Then P0787,P0973,P0976,P2764,P2769 which are all low circuit transmission errors.
Paid an Auto electrician who said all the wiring etc was fine, and suggested it was a solenoid issue. I've swapped out all the solenoids, but still have the same issue.
Occasionally it will run fine and shift through all the gears normally, but once I stop and restart the car it's back in limp mode again.
Not sure if it's relevant but 5 days before limp mode started I had a rear wheel cylinder fail and had to drive home with limited braking. But it did run fine for 5 days once I had repaired the wheel cylinder.
Any info would be greatly appreciated, thanks.
