VN_SS_CM
nah its a bitza this type of car....VN with a VS Stato dash mixture of vn dash wiring and vs wiring but no BCM or plugs...using a VR stato BCM only has 1 wire that goes to the solenoid and the other end to 12 volts ignition
Thats what I'll be doing when either my pump or my rack shits out.Fit a standard rack. That way you’ll be able to purchase parts for it such as the high pressure line/hose and source extractors easily.
I did, if it wasn't for the fact that my front tyres are pretty meaty in width I'd be tempted to do it.Did you see the recent episode of Kevin the Savage where Turbo Yoda "manualises" a PS rack?
Yeah I have three racks and sets of hoses here but still present fitment issues with a decent exhaust unfortunately. I used to run the HSV headers but you just don’t get the same sound from them as you do a set of pacemakers. Plus since they’re thin stainless they always crack at the collector next to the welds.haha I would but I have 2 complete sets with Pumps and hoses at my disposal
Set 1 - Recoed rack, new hoses, new pump
Set 2 - less than 5000kms and once again recoed rack, new hoses and new pump..
Running stock hsv style extractors....but I can see what someguy360 means if you where to get extractors they would have to loop around,
I actually have a manualised VS rack here it has had the insides removed and the torsion bar welded, tested it for a month and pain in the ass when trying to park....I was told I should have adjusted castor but meh pulled it out.....
