vb 253 dizzy swap?
leigh 7005
adelaide
vb sle
ok ive just got a electronic dizzy and wanted to know a few things.
1. should i run a wire from the pink ignition wire to coil to run constant 12 volts.
2. can i run my tacho or will it stuff it?
and is there anything i might run into?
:dance:
vkberlina
VK Madman
42
NSW Central Coast
www.members.westnet.com.au
The pink wire is the ignition wire, tacho will remain the same no change.
best move you will ever make. make sure you vac advance is working on the new dizzy by sucking on the hose. if you suck air through it its failed and needs to be replaced (pretty easy job).
cheers
scott
leigh 7005
adelaide
vb sle
so the tacho will be fine running on the 12 volt coil? i heard some where it can stuff them and the vacume advance should work cos its new thanks for letting me know as i didnt know how to test the vac advance exept with a timing light.yea the pink wire as i was going to put a kill switch in as well.
Tom_1569
Ecotech Power
Gippsland - VIC
'14 SR5 Pusslux
Theres alot of info on this on oldholden.com and the holdenpedia.
From memory you need to upgrade the wire, so it gets a full 12volts, and some people also used a relay.
There is talk of the Tacho (in GTS Dash's) suffering after a while, maybe have a search or ask on Oldholden as it seems to be more common conversion there.
