Bit of a long story short,
As I did a thread on the remove of the tank trice then cut a hole on the floor for third time, that saved me dropping the tank again.
When mine failed, I didn’t realise the loom plug was burnt, but I did bash on the floor pan and it fired up,
So I was able to drive it home,
Then the following day I pulled the tank out, and the unit thinking it was the tank unit, and found it was the loom plug,
Sourced a loom with the same plug, and spliced the plug onto the original loom for around $40 I think,
A replacement loom was going to cost over $200 and a week to get hold of.
Got another tank unit from Repco and it’s wasn’t the correct one for the L77.
Found a seller in Coburg on eBay that claimed they were OEM quality, then dropped the tank again,
but the fuel gauge sender unit failed on that after 14 months, just out of warranty, spoke to him and basically said bad luck mate, it’s out of warranty.
As it dropped to empty at 3/4 and at 1/4 of a tank and cause a X on the dash with contact dealer.
So I bit the bullet and cut the inspection hole in the floor pan (done a few pages and photos on that)
I have since put the original tank unit back in, with the original gauge sender unit, and hasn’t missed a beat,
With the OEM tank unit, you are able to replace gauge sender unit as it plugs in under the top of the tank unit,
But,
The cheap crappy aftermarket one from the ripoff armhole in Coburg is soldered in, so it’s not replaceable, like the OEM one is.
And I wasn’t going to waste my time f____ around with a so called OEM quality Chinese crap, as I have binned it.
Morel of the story here, go OEM.
