L
losh1971
Guest
I'm in the same boat to remove the exhaust it's unbolt it at the cats and remove the whole thing. Mine is 3" too but MagnaFlow. Can you not undo the rear mounting bolts and lower it enough to get to the plugs? I bought the long inhex set as I was tired of undoing the rear mounts and rubber hangers.yea with the DPE 3'' it sits right up at the fill hole bout a finger width gap to play with, and that whole middle piece is one so have to undo it from the headers and rear mufflers to get to it properly, yea stock diff is still hanging in there but i dont do any big clutch dumps just when its loaded ill use the throttle unless it arcs up with a spirited gear change, i have some stronger axles to go in and ill look at diff when i can, ill prob go with the kaas as it seems better for what i want as it dosnt torque vector like the harrop i dont want it changing sides just want both to lock under power
+1 for a Kaaz, but you will need to change the oil at 1000km then again in about 5000km, and then about 10,000 and 15k changes after that. They have a run in period where you need to keep it under 80kmph and stop and let it cool every 50-80km for the first 1000km. They generate a lot of heat in the first 1000km and that can damage them if not cared for. My run in period was drive it to work, park and let it cool then drive home.
Also don't use Progear in a Kaaz or you will damage it. You use the Kaaz oil for the first three oil changes then a 140 mineral after that with the additive.
