VE SS split engine covers?
3_putt
35
S.A
VE SS ute
anyone had any luck in finding some correct fitting split covers? Read that the VZ 6L ones fit with a little fiddling. But I’m thinking of cutting up the factory covers as the clips will still be retained after cutting.
MYVESSV8
Brisbane/GoldCoast
VE 6LT M6
cut the centre section from mine, put in a bit of mesh (supercheap) just made up 2 brackets to support on the outer sides, mount to coil stud and small S/S bolt hold it steady on cover
VS_Pete
Donating Member
They look good.
3_putt
35
S.A
VE SS ute
Yeh i ended up cutting the middle out of mine. You say you made more mounting brackets, weren’t the original ones sufficient?
MrBags
45
VE SSV Z SERIES
My old man painted his the body colour then cut out the middle sections on his and put some steel mesh in place of that, looked pretty good actually.
VS 5.0
Is specific heat proof paint required when painting these ?
3_putt
35
S.A
VE SS ute
That’s not bad, I’ve already got the grinder out on mine though! About half way done with my covers.
I’ve bought high temp paint just to be safe. My engine bay gets ridiculous hot due to my un coated extractors.
went this way with the VF. expensive but i liked them
cheers
Unfortunately for me having walkinshaw on them didn’t work. They are pretty much what I was after too!
