VE SS trans cooler issues after fitting
Big O
54
western australia
2010 VE SSV S1
Hi all, its my first post so forgive me if this has been covered before. I am fitting a transmission cooler to my 2010 VE SSV as I do some towing. I plan to bypass the existing exchanger in the radiator. Does anyone know of any issues with the trans after fitting the cooler? any help would be appreciated.
cheers
Big O
54
western australia
2010 VE SSV S1
awesome, thanks for that. I bought the PWR kit specifically for the VE
Big O
54
western australia
2010 VE SSV S1
Ive only recently bought my VE so haven't played with that yet, I need to check the before and after temps
vr304
Auckland, New Zealand
2007 ssv manual
So long as u replace any fluid lost you’ll be fine, might be a good excuse to drop the fluid and replace with some fresh stuff and a new filter
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
This is good advice!
Big O
54
western australia
2010 VE SSV S1
Great advice guys, I think I will do a trans service at the same time.
EYY
VS Statesman
You shouldn't bypass the factory cooler. Remember, the copper/brass heat exchanger is in direct contact with your engine coolant which means it's MUCH more efficient at transferring heat than a heat exchanger exposed only to air. Best to run them in series to get any real benefit.
