clutch1967
- Jun 11, 2019
- 26
- 0
- 1
- Location
- shepparton
- 04 SS , 06 ve sedan , 79 VB SLE
does anyone have or know the wirng diagram pin location of the transmission on a ve 6 cyle gearbox
I am trying to find out the pin location of a 2006 ve and a 2009 ve
the difference in the pin locations
I put a gearbox out of a 2009 ve into a 2006 ve
and I have found that the plug has different pin locations in each car
its putting up a code of no earth between 2nd and 3rd gear so wont change gears
so I and after the locations so I can change the pins to make it work basically
before I did the change I did talk to holden and thay told me that everything is the same and would be no problems in the swap
