IN the engine? Or the belts maybe?I don't have a clue WTF is wrong with it, never heard a car sound like this. It sounds likes like a squeal in the engine when I get it to start.
ok be very specific here, what did you mate touch/remove/move/unplug?
I think it probably has a vac leak and the noise is probably a belt.
Will it idle on its own? Ie Will it continue to idle if you take your foot off the gas?
Can you get it to continue to idle using the gas pedal?
Check for sanity sake that your oil is at the full level and your not running ridiculously low oil.
Why did he need to remove those plugs? Did he attempt to clean the throttle body?
