how to reset ve commodore sv6 ecu?
A
acca00
Guest
does anyone know how to reset the ecu? disconnect the battery pump the brake or something? i heard you can disconnect fuse and it will do the job
EnFoRcEr_001
Deano
VE SV6 A5
umm.. i am not too sure on this one. i know on other makes simply disconnect the battery for 30 minutes or so and that should do the trick but not sure with the ve's
tariq
Bahrain
VE
Any update for how to rest computer for VE ??
philsv6
VE Sv6
i know disconecting the battery for 2 mins resets fault warnings, not sure if it resets the ecu, i surpose so
greenacc
Searching for the billion
VE Berlina
yeah, i reckon phil must be right. disconnecting the battery will ( Should ) reset the ecu just the same as it did on older commodores. The longer you leave the battery disconnected for the more likely it is to work.
On a VS it also helps to try starting it while the battery is disconnected as it seems to drain any residual power.
J
jonnyden81
Guest
How to reset km's in a VE SV6 2006
Is it possable to reset the ECU VE SV6 holden 2006. ?
footy
VE SSV SE 2010
yep just get a new engine
IceyAUS
SA
VE SSV Series II Sedan
Is it possable to reset the km's on the clock of VE SV6 holden 2006. ?
Yes, a few steps involved tho.
1. Tune the radio to 88.0 FM
2. With the key in and turned to acc put the interior light on
3. Pump the brake 4 and a half times
4. Turn the interior light off and at the same time open the glove box and the passenger side door
5. Take the hand brake off and put it in reverse
6. Now tune the radio to 107.6Fm
7. Pop the fuel cap while rubbing your nipples slowly
8. Now turn your car on and it will reset to 0
Easy as that!
itsArthurKomar
sexy beast
ya asss
super awesome time machine
BAHAHAHAHAHAHAH made my night :D this is a +1
Easy as that!
