Poor old Dad
- Apr 4, 2011
- 351
- 283
- 63
- Location
- Brisbane
- VFII Calais V
You should of ordered one with the lot!
I did but they told me that it was only Threeways...
I’ve understood that all main beam headlights over 2000 lumens were required to have levellers and washers fitted. And this was still the case even after the ADR’s becoming pointers to the ECE regs (R48 lighting systems, R98 xenon headlamps, R112 Halogen headlamps & R123 Adaptive headlamps and probably more). But understanding and certifying lamp assemblies is mired in complexity.HIDS to be legal still require washer and leveller, LEDs supposably now only need to comply with the same requirements as filament globes, though some may require canbus modules.
yeah im sure you probably have to read into it more than just page 9 of thisI’ve understood that all main beam headlights over 2000 lumens were required to have levellers and washers fitted.
Still doesn’t change the fact it’s illegal as it’s non compliant with ADR’s/ECE Regs.There’s a Falcon down the road from me. Often drives out behind me on the way to work at 3:30am. Full LED conversion. Number plate, indicators etc. The headlights, while brighter than the factory dolphin torches, are in no way a distraction to me until we get to the intersection and go our separate ways. Obviously using quality LEDs that put the light into the reflector better than halogen.
It’s a tidy ride.
that doc states things rather clearly, so maybe conformational bias?yeah im sure you probably have to read into it more than just page 9 of this
but interestingly its only under the hid section they specifically call out lumens and levelling and washers
