If you are not home don't you take your keys with you?I've already installed a monitored alarm and cctv system, next I will be putting roller shutters on the external windows and looking at improving/adding door locks. I'm also looking at getting a small safe to store the keys in for some added security.
Just on that topic... With the VF proximity key, if you were car jacked and had the key in your pocket, does the car switch off once it is no longer in range of the key?I think if they really want your car, why bother with stealing it from your house when a well executed car jacking would do the trick.
Great question, as I know nothing about VF security.Just on that topic... With the VF proximity key, if you were car jacked and had the key in your pocket, does the car switch off once it is no longer in range of the key?
Yes, I believe so.Just on that topic... With the VF proximity key, if you were car jacked and had the key in your pocket, does the car switch off once it is no longer in range of the key?
Thanks, that's good to know.Yes, I believe so.
