Having someone come into the house looking for keys while we slept was the catalyst for the bowl.
Getting their hands on the keys is something thieves often have to do to take a late model vehicle from your residence though I’ve been told this isn’t always necessary as the real pros can get around it.
When we go on holidays all the keys along with the dog are sent off to the baby sitter.
Both of the cars I had stolen from home were steel bumpers and as you've pointed out they came with no security and it was as easy as breaking the cowl on the steering column and reaching in for the rod that connects to the key barrel and pulling it to start these old girls.
With the car taken from the garage I had a kill switch under the seat plus a battery cut off disconnect pin fixed to the boot as per drag racing requirements and the battery relocated to the boot.
The battery wasn’t with the car it was on the bench in the shed out back of the house with the rotor button and the disconnect pin was in the house with the keys.
A club lock was fitted to the steering wheel and brake pedal (hopeless I know but it stops the joyriders) and it had two chain points into the concrete floor, one wrapped around the diff housing and the other wrapped around the engine cross member.
The thieves broke a window to access the garage, cut off part of the steering wheel rim to remove the club lock and replaced the wheel with a nice HDT Momo wheel, popped a battery into the carrier in the boot and ran a cable from the battery over the roof and down under the bonnet near the master cylinder to the starter motor and ran a lead from the ignition switch to the solenoid, they pulled the door lock out and broke the cowl to access the ignition, fitted a rotor button and cut the chains.
I came home to find the garage door open and no car.
The car in the carport had an alarm with motion sensors and nothing else, they came into the house while we slept and found the keys.
Both cars were recovered though one was nothing but a burnt out shell.
It was after they came into the house that my wife started to become concerned with me having high risk vehicles around and an old codger like myself told me to keep the keys where they can be seen and they’ll never feel the need to disturb you.
If I had just an ordinary everyday shitter or something common as salt then hiding the keys would probably work, if you have something sitting around that is worth the extra risk for a thief then let them have it as it’s not worth your life.
Here’re some news articles on the subject.
http://www.abc.net.au/news/2015-07-...s-to-break-into-homes-across-adelaide/6587564
http://www.adelaidenow.com.au/news/...s/news-story/366033e524c93643340ae71ac815dfea
http://www.abc.net.au/news/2015-04-17/proximity-keys-car-theft-hackers-raa-freezer/6399650
https://www.crimestopperswa.com.au/the-one-mistake-most-car-theft-victims-make/
