Yes I did. This is what my father reckons may be the cause. How would it affect the car though, if you can explain it to me?
Yeah i just called them and booked it in for Monday. Its just my first time doing any of this and i just wanted to get a few opinions. Its still under warranty so that would mean anything would be covered right? Thank you
Technically, I cant explain it to you and/or would not B.S you.
The fuel may or may not be the cause of your issue however, I had a similar experience with my local BP fuel station. I believe they had a bad batch of BP Premium fuel. I filled vehicle up with the same octane fuel at another BP station issue never occurred again.
It may be worth investing in a OBD Scantool which are relatively cheap to look for any fault codes your vehicle may be throwing and you could research the fault codes.
As your vehicle was just serviced, maybe ask your old man to help you have a geez at the oil to ascertain if its fresh and if possible check if a new oil filter has been fitted and/or check your radiator to ensure its at the appropriate level.
