TPMS 'caps'?
To enter learning mode: Press and hold the Start Button (Without placing your foot on the brake pedal) for around 5 to 8 seconds, the car will enter into an 'ignition on' mode
Use the normal means on the indicator stalk to bring up the actual TPMS display, with the car graphic and 4 wheel pressure figures.
Press and hold the button on the end of the stalk a few seconds, the car will ask to you want to relearn the tyre pressures, rotate the knurled knob to highlight YES and then the button again
The horn beeps, the left front indicator turns on, and it's time to do the trigger tool thing. When the system has registered a reading for the L/H/F wheel, the horn will beep to signify success, continue to the next wheel.
Do all 4 wheels L/H/F, R/H/F, R/H/R, L/H/R.
When L/H/R is done, the horn beeps, then a few moments later, beeps twice to indicate all is done, you're finished, the car exits learning mode automatically
...Was anyone though able to confirm if you could complete the manual learning mode procedure fully on the VF/WN by allowing air to escape on each tire in sequence as shown in the above youtube clip?
@Red Centre Bluey , did you bother to get back to the dealer that ried to charge you for new TPMS sensor when there was nothing wrong with them? If so, what did they say?
As for replacement TPMS sensors, at $371 a pop, we seem to be ripped off big time down under.
The Chevy SS TPMS sensors are <<$80USD a piece, see here.
Also, do you know if there any difference between the various EL-50488 devices on ebay? Some seelers state their $16 devices are for GM vehicles up to 2013 while others state little if anything?
Hi if you are buying tpms sensors from the states make sure you get the correct MHz tpms they will be either 433MHz or 315MHz, When I got mine from the states my local dealer was kind enough to tell me what part number is paired to the RFA.
E.G RFA 25856316 is superseded to 25938218 on the VE/WM This RFA uses TPMS sensor 92186507/25789964. When you put these numbers in the search on fleebay they will come up with the part number and the MHz. 315 will not pair with a 433MHz RFA and visa versa. As for the reset tool itself same again make sure when buying the EL-50488 it is for 433MHz as it will NOT program the 315MHZ, there is also an EL-50488 315MHz, So please make sure you do your home work
