Mate, 2650 is awesome! You won’t be disappointed. As others have said, you’ll probably need a fuel system (I’ve got a KPM 1500). For context I’ve got a 2650 on an stock bottom end L77 with Higgins Heads and a mild cam, LSA front drive and it made 785hp on e60….it’s immense fun! You really need to roll into it, otherwise it all ends in a cloud of tyre smoke. You will struggle not to beat on it for the sheer joy and blower whine is addictive. Enjoy the journey!Hi all,
Got myself a new toy. Practically as new with 30k kms. Manual.
Plan is to have a 2650 supercharger installed with all supporting bits and pieces. Stock bottom end will remain.
Curious as to how these ‘manage to put their power down with 550-650rwhp? At what sort of point do they just become tyre frying monsters that can’t really put it down? I’d like to keep it just under this point, ideally.
I’ve previously owned a HSV Clubsport LSA which put the power down beautifully but was stock, granted.
The car won’t be flogged, raced or abused nor have an aggressive cam etc.
Cheers!
I believe thermal spacers and a HTV2300 fits under the bonnet of a VF
Tag your it @VF Sleeper
I second the 12l reservoir and 8pk belt, though I’m only running an 80mm pulley. A mate runs the interchiller system on his ls3 with a 2300 and swears by it.I have the FDFI Harrop 2300 and thermal spacers. Fits no problemo. No clearance issues for the VF.
I reckon 600 rwhp is plenty for the street. Any more is only good for the track or bragging rights.
1. Get the absolute best possible new high performance sticky tyres for traction. So far, I've been happy with Michelin Pilot Sport 4S.
2. You've gotta use the accelerator carefully. The stock traction control and stability control does help. I bet it's not as good as Ginger's aftermarket system. If it's turned off, it's sure it's easy to spin the tyres or quickly get out of control. You've gotta feed the power on carefully. Even half throttle and you're moving faster than most. I only stomp on it at the drags.
what are you thinking here? It could be a long list.
If I had my time again, I'd probably do a few extra things from the get go. The top ones for me would be the interchiller and 12L reservoir, the 8PK LSA belt system with 75mm pulley, catch can and the 3.45 diff ratio.
Never a truer word has been said.You will struggle not to beat on it for the sheer joy and blower whine is addictive.
Where do you even get E85 these days?if ur on E then u dont have to worry about chiller ur not going to see any knock, if ur on petrol then yea it helps
