VK Elec antenna mast, is there a replacement avaliable?
Staggie
VT Calais S1, VK Wagon EFI 5.0L
Hi guys, posted this in the car audio thread but got no joy out of it so maybe someone in here knows.
Does anyone know if there is a replacement mast available to suit a vb-vl elec antenna, don't particularly want to go thru the hassle of replacing the whole unit and having to take most of the dash apart. The rope on mine is busted.
vkberlina
VK Madman
41
NSW Central Coast
www.members.westnet.com.au
for starters you dont have to pull most of the dash out actually barely any of it
Remove the inner guard
Remove the kick panel
remove the under glovebox trim
Undo the screws fitting it & and mast nut and remove 30min job max
your best bet would be an after market semi auto antenna
cheers
Scott
Staggie
Cheers Scott, I was under the impression that the antenna cable ran over the glovebox, although can't exactly remember, has been a few years since I've done one. Getting to the back of the radio will be the fun part from what I remember with the stock items.
VR38
VB SL/E
Pull he dash apart to replace the antenna? It is under the front guard.
Staggie
Yeah but the cable goes all the way from the antenna to the radio.
VR38
VB SL/E
so you need to remove the radio to disconnect/re connect it then feed it thru the firewall.
DerekP
VH SL/E 5.0
You might be able to get behind the radio to pull the antenna cable through the speaker cover on top of the dash, assuming the VK has one those....
vkberlina
VK Madman
41
NSW Central Coast
forgot about the antenna cable, you can undo it from behind the ash tray if your good, one tip with the antenna cable, tape a draw cable to it, pull it back then when you fit the new antenna, pull the cable through.
cheers
Scott
Adelaide, SA
00' WH Stato LS1 A4
cant you just remove the antenna from the guard, cut the old antenna cable, install the new one and tape the new cable to the old one and just pull it through using the old cable?
VR38
VB SL/E
Yep, I think the point is the dash does not need to be removed.
