you will require to remove the bar moulds first
these held on by 8mm bolts on the inside and a few clips you squeze with pliers
remove the end mould covers near the wheels first ( one screw and slides off)
now remove the two 1/4 panel moulds (two screws at the most rearest point and clips too the front)
once loose slide the mould outwards of the car so the rear edge slide out from under the rear mould
repeat for both sides
next the rear mould, this is clips and one screw if a recall
once loose just straight backwards
once the moulds are removed you can look at the bar,
there are two bolts that go through the 1/4 on each side too the bar, remove these first
onder near edge of the bar at the bottom of the 1/4s there are a black plastic clip witha screw centre, try unscrewing it but more then likly it will not turn, just leaver the screw centre out
unplug the number plate light from the inside connector as its easyer then trying to do it while holding a bar
then just the 4 main bolts, think they were 12mm and its free
simply flare the ends out a little so it will get past the edge of the wheel arch
and remove it
get a hand from someone to lift it off the car safely,
simple just unbolt the section you wont or dont (3 x 8mm bolts on inside flange) and reverse the order, just dont forget too feed the number plate loom throught the hole
makes sure when you put it back together that you do a few things
-make sure the sliders are in the sides of the bar for the 1/4 panel bolts
- number plate loom get feed in
- when fitting all the mould on the rear centre one goes on first then the sides, or you will scratch and crack it trying too fit
-never bolt a bolt up tight, get them all started a few threads first then when all the bolts are in adjust the bar how you like and tighten
need anymore help or get stuck just ask ill be glad too help
