I was looking at increasing capacity of sump
Have also assumsump 3 litre accumulator was going to use in boat however would be better suited to 5 litre
Looking at heads in weekend
Wonder whether you can drill the oil drains out a little
Cam bearing removal/install turned up today
First time I’ve taken the bearings out myself, easy to use
Now need to look at restricting #4 cam bearing
Need to have another read of come and geoff article so we get it right first time
Yeah he said it didn't have oiler.
Most go about restricting oil to top end first hence roll pins & roller rockers.
After that can drill out & chamfer pushrod holes & oil drainback.
Move breathers or add to manifold.
Drain back added to rocker covers with lines back to sump.
Then can think about cooling system tricks if game like diy water recirculation mod HDT did to rear water passages & finding cast impellor blade water pumps.
See if this thread turns into sticky if op does all the ol' skool tricks lol
