Zinc coated, and then first coat of epoxy paint on K-frame.
Disassembled disc brakes, rotor are okay measure up + 22.5mm thick, pads are good just rusted, but will toss them for new.
Removed wheel bearings, seals seem okay however will install new,
sway bar bushed need replacing,
lower control arm and tensioner bushes were replaced with urethane previously and all look good, strut locators were upgraded previously. Need to get some coil spring clamps so can take off the springs and clean them up, paint the struts and springs. managed to find a sticker on spring with ID 02020076...not sure whose spring it was as was on car when I purchased it, however will leave them as is, as only been sitting in one place for last 16 yrs so should still have plenty of life in them
had a job getting the nut off the rear tensioner rod/bush off the low control, as didn't have a 30mm, had to cut off nut and use chisel, so need to organise replacement. will tackle the other strut tomorrow
For the 2nd tensor arm went and purchased the 30mm socket much easier and less mess to worry about afterwards
