Deuce
Super Stock
- Feb 5, 2012
- 4,572
- 4,874
- 113
- Location
- Snobs Rock (or so the locals say)
- '94 VR SS V8
It'll make 450hp at the engine.not sure, things evolved from standard build to stroked 350ci engine build, forged pistons will sit at 10.3:1, H-beam rods:, HR 0.597" lift, with 107 lobe separation, VN #0019 heads, and valve gear to support Hyd roller, block work and oil galleries done, 8 litre sump, oil pan vacuum pump, 3000 stall convertor, transmission still thinking, T700, however would like to throw a 6 speed 6L80 into it, 3.9 gears on Limited slip. I have a twin forward 70mm throttle body manifold there and have few sets of different size bosch injectors
Still thinking about what to do with ecu
what ever comes up, I'm okay with that, as long as there is enough on tap to get out of its way when needed, I plan on driving it, as its been parked for too many years, however for now we still sometime off
I would say beef up the 4l60e. It is easier wiring/tuning/fitting obviously, and people have them behind 9/10/11 second combos so no reason it wouldn't work, unless you specifically wanted extra gears, but they are good enough for street cruising.
