I had that- the classic symptoms of a blocked evaporator drain.I have a vn calais v8 and when running the air con get cold water leaking around the left foot area mainly when turning, havnt had any issues with the air con otherwise.
Can you post a photo of the hole? I plan to drill one and try cleaning the evaporator drain tube from above.Someone, not me, has drilled a finger size hole in the side of the heater box on the passenger side right down near the bottom. It's plugged with a tapered cork so it doesn't blow air during general use. With the plug out ` vDeedI can reach in with a finger and feel the top of the drain hole and feed a large cable tie DOWN the drain tube. A good mod. Much easier than doing it from below.
A `blocked drain tube is the likely cause of the OP's problem.HOWEVER, if tempted to drill an access hole as above, I recommend ensuring the heater box is drained FIRST. A week or 2 ago I noticed some water in the footwell after a drive and pulled the plug to clear the drain and about a litre of water gushed out into the passenger side footwell. That wouldn't be a good mix with an electric drill.
Drilled the hole. Needed a 1.6mm wire with a tightly looped end to clear down to the outlet alongside the transmission. If I did this again I'd drill the hole 10mm to the right.View attachment 244637
The hole is normally just above the round bit that goes through the trans tunnel.
