Trevor loves holden.
- Jun 6, 2019
- 3,508
- 750
- 113
- Location
- Victoria
- vs commodore
2 different kits.
Kelso are from Holden, if his got the normal one you can get gasket kits but I say its only the pressure control valve is the issue.Big T those aftermarket pumps are garbage. The only good pumps are genuine. I can get a rebuilt gen pump for cheaper than the **** ones you listed, just saying.
I believe the VP rack in the v6 or V8 are the same as VQ.Thanks. I have the original GMH VQ manuals and I had a look today. The VQ system is a bit simpler than the VR/VS looking at your attachments.
I picked up a rebuilt pump today- for some reason the variable steering Saginaw pump is different to the standard steering VP V8 pump- the older guys at the parts shop were adamant about this & checked the part number on the pump case before they would sell it to me.
Long as there no blockage in the rack fluid system I don't see it be a problem, fingers crossed.Thanks Trevor. I've got a rebuilt original pump- fastest way to get the car back on the road. I hope the rack's OK- it worked fine when tested with the wheels off the ground as you suggested.
