vr 5.0 lost 4th
cromo_69
VR Calais 5.0
hey guys just wondering if the box is stuffed if you lose 4th?? As i was almost home from work 2day when all of a sudden 4th decided to go... it still drives/shifts fine in 1st, 2nd, 3rd just got no 4th
checked the fluid and its about 10mm above the hot mark (40 mins after i got home)
checked the codes and comes back with code 75- system voltage low... wtf does that mean lol
88GreenVN
Next Exit Left
58
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
Code 75 Auto trans only - so I'd check the plug connection for the trans loom - see if it's making good contact.
cromo_69
VR Calais 5.0
where bouts is this loom??
cromo_69
VR Calais 5.0
so i took it for a drive and i have 4th back :) but when your doing 80 and lightly press the accelerator there is a vibrating/ shaking thing that goes on but goes away below 80 and if you press the accelerator harder
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
could be the torque converter clutch slipping.did you reset the ecu by dissconnecting the power for 5 minutes and see if the last code came back again
cromo_69
VR Calais 5.0
nah will do it 2moro
