VR 6 heater core flush
Dunlop
68
Beechworth
1993 VR Commodore Acclaim
Hi Everyone. I've been looking through as many of the posts I can on how to flush a heater core. The only thing is that I'm still a bit confused and need to ask a few silly questions (it gets pretty cold in winter where I live).
Firstly, I originally thought that the pipe that goes into the firewall at the top at the left hand side was the input for the heater core as it has some black foam lagging on it, but apparently it's not? If this is not a heater hose, then...?
Secondly I now gather that the input and output hoses to the heater core are side by side or one under the other on the drivers side partway down the firewall in a slightly awkward place and seem to have other smaller hoses connected to them to make things more complicated?
If this is the case, I need to pull these off to attach some tubing in order to do the flush, and could someone kindly tell me please which is the input hose and which is the output hose as I understand it needs to be reverse flushed?
Many thanks.
Fu Manchu
WA.
Over next to the brake booster. Just two rubber hoses. You can disconnect from the firewall or from the heater tap.
the_boozer
no more VK
51
Shitsville Morwell
hilux
running a garden hose thru the heater core wont unblock it, if its full of crap and not making any heat putting a graden hose thru it wont unblock it.
Fu Manchu
WA.
If the heater core is blocked and flushing doesn’t work, it’s dash and hvac out. Huge job.
Immortality
Staff member
Sth Auck, NZ
Reverse flushing the heater core with the garden hose can work, I've done it a time or 2.
losh1971
North Tas
VE Series I SS Ute
It will come down to how blocked it is. A reverse hose flush can work sometimes. However if the heater core has been blocked a long time or if it's dry blocked, the hose probably won't work. But given its cheap to do its worth seeing if it helps. What can happen is the flow of pressure tends to take the path of least resistance depending on the blockage. Make sure you use a good chemical flush first.
Dunlop
68
Beechworth
Thanks to everyone for all the advice - sorry for not replying as the updated posts didn't seem to come through my normal mail. Still haven't flushed it but have put in a 91C high flow thermostat (car now has a new radiator) so the engine runs warmer to help. Hoping to do it possibly this week if I can. The heater isn't really blocked as it still works but not as hot as I'd like (as said, it gets pretty cold here). I suspect some gunk has built up over time so a flush should hopefully make a bit of difference.
  • Like
Reactions: Lex
Dunlop
68
Beechworth
I only know too well and wouldn't attempt it. Have watched videos though on how some people have cut the pipes to get the core out and it saves a LOT of work. Thing is it's still working. Odd really - last two cars have had issues with their heaters.
