Deuce
Super Stock
- Feb 5, 2012
- 4,511
- 4,752
- 113
- Location
- Snobs Rock (or so the locals say)
- '94 VR SS V8
Progress continues:
All fuel sorted (and checked for leaks - all good). Booster vac, map, heater cntrl vac sorted. Carbon canister is hooked up, pcv is on. Cruise and throttle cable sorted - bracket re-drilled.
Temporary clutch fan delete for testing - will fit fan back on later.
Just need a little vac line tidying and sort out engine breather for drivers rocker cover.
Tried starting last weekend - fail. Cranks but no hint of firing.
Adjusted timing advanced. Tried this weekend - almost. Tried while jumper leads on for max starter power - and it runs. . . . really horribly and won't idle.
Plan from here is triple double check timing and reset to stock. I think I'm still a way off.
Then finish off little things ready to drive again and build a new tune file.
