VS 2000 ute (ex ambulance)
Discussion in 'VR - VS' started by CNsylvester, Feb 24, 2009.
  1. CNsylvester
    CNsylvester New Member
    VS long bed ute
    Hi everyone
    I've just finished the young family and baby scene family car routine and decided its time to buy my first ute and live again!
    I chose a LWB VS because I need to carry special other vehicles in the back.
    My ride is an ex ambulance by Jakab - Tamworth. (much different from my old HJ Caprice - my last GMH). These are 600mm longer than the standard VS and extended in the area between the cab rear and the wheel arches.
    I bought it with 89k on the speedo and with the ambulance pod still attached. I've been slowly bringing back to a decent ride, my ride.
    Returning it from an ambulance to a ute included:
    Disconnection of the A/C and electrics to pod
    Purchase of 6 side panel covers and 2 fuel tank covers for the ute tub (removed to reduce weight apparently).
    Purchase of rear window
    Purchase of tail gate
    Purchase of 2 bumperettes
    Purchase of 4 tonneau rails (they remove these for fitting of the pod
    Regass the A/C
    Relocate the number plate lights back to their original position
    And thats about the start.
    Next is:
    Suspension
    Roll bar
    Tub cover (hard or soft?)
    Sound
    Tint
    The SS wheels helped a lot and the whole unit gets heaps of second looks.
    Any hints, tips or comments most welcome.
  2. nathg
    nathg New Member
    hills area, sydney
    MX83
    Any pictures?
  3. STEALTHY™
    STEALTHY™ So Wet For You!
    SA - The Roadworks State
    Are you in adelaide, i've noticed one driving around a bt lately!
  4. CNsylvester
    VS long bed ute
    Yup, photos hopefully attached and I'm in Queensland.
    This thing performs so much better without the pod. I just know I'm going to get a ticket before too long.
    Regards
  5. Haydz
    Haydz Fasten your seatbelts
    Liverpool.Sydney,NSW
    VS UTE LS1 T56
    sweet as man..
    love the look of the extended ute..
    that must be a longer wheel base than the statesman etc.
    good luck on your future mods.
    from the look of the pictures it would benefit from some lower springs.
  6. Turd Ferguson
    Turd Ferguson Donating Member
    N.S.W
    Disco
    cool, ive seen one of the long wheel base ones around here also, they definetly grab ur attention
  7. CNsylvester
    VS long bed ute
    yep the suspension hasn't been changed from when it was an ambo. Thats next on my list. The ride is currently hard.
    I had a work Crewman at home recently, the Ambo was still approx 10cm longer in the wheelbase.
    The mrs said it doesn't grunt enuff (comparing to the old HJ 308) !!
  8. STEALTHY™
    Considering a normal ute is the same wheelbase as a stato, it would have to be lol
  9. TUF UTE
    TUF UTE Dave
    adelaide
    05 VZ SENATOR
    if anyone wants one of these in sa. a mate has a 5 litre one on gas lowered with body kit, and its not thrashed.. hes forty and uses it as a work ute.
    gotta love these things though :) more pics mate :) particularrly inside the back
  10. STEALTHY™
    Thats probably the one i saw then;)
  11. TUF UTE
    TUF UTE Dave
    adelaide
    05 VZ SENATOR
    lol hes up in the adelaide hills dude :p its tough though.. and 5 litre which is odd
  12. CNsylvester
    VS long bed ute
    Photo of inside the ute should be attached I hope.
    When the ambulance pod is removed, none of the normal ute tub panels were present ( I had been alerted this might be the case). Apparently they are removed to reduce all possible extra weight.
    I had to buy 2 fuel tank covers so the body worker could weld them together to make one large one to cover the space. I also had to buy 6 smaller panels for the inside walls of the ute tub. The wrecker guys thought I was nuts.
    The inside was painted by a paint shop with an industrial strength skin. Seems ok.
    Note the rear window also from the wreckers with the free sticker (I picked that window esp!)
  13. CNsylvester
    VS long bed ute
  14. CNsylvester
    VS long bed ute
    Quick question - I was underneath the rear end today, near the spare wheel, under the floor of the ute there is some apparatis (could be mistaken for a wire coat hanger) with a chain attached and has a brake line going into it.
    What's it for?
    Regards to all
  15. TUF UTE
    TUF UTE Dave
    adelaide
    05 VZ SENATOR
    brake bias adjuster. adjust your brakes accodring to the weight in the back
  16. CNsylvester
    VS long bed ute
    Thanks for that davecunno -
    Another question - has anyone tried to put a statesman interior light into a ute? The ute roof curves at the light position and the statesman light is slightly longer.
    ThankS!
  17. boonga
    boonga New Member
    Alstonville Northen Rivers NSW
    vz s pack ute
    you should cut it up and make a crewman out of it
  18. CNsylvester
    VS long bed ute
    I did a quick search and didn't find anything...
    has anyone ever mounted a small winch inside the tub of a VS ute? ( to assist moving bikes etc into the ute)?
  19. CNsylvester
    VS long bed ute
    Well this week I had it lowered, 2 new tyres and installed a woodgrain stato console.
    Pleasure to drive + some extra creature comforts now!
  20. fuzzy2308
    fuzzy2308 New Member
    Plastic datsun
    nice Ute man i love the long wheel base ones, it'll look sweet as slammed maybe even bagged with 20's. i would loose the cowboy sticker throw
