Draimond
- Aug 28, 2008
- 285
- 260
- 63
- Location
- Brisbane
- VS V6 Executive
Done:
To do list:
- Finish rust repair and clean more.
- Respray engine bay.
- Rear main seal.
- Swap to modded sump.
- Make new starter motor cables.
- Install big injectors.
- Polished plenum and misc alloy bits.
- Re-sleeved thermo fan wiring.
- Install new sensors.
- Plumb Turbo - oil and water.
- Make a custom oil dipstick to suit turbo placement.
- Add AN fitting to rad for turbo water drain back.
To do list:
- Catch can needs a drain plug.
- Paint k-frame, sway brackets, brake booster bracket and catch can in 2k black.
- Finish engine wiring harness.
- Add new fuses and relays.
- Replace cooked oem wiring.
- Replace 2x BCM connectors in engine bay with 1x DT12 pin. (May require dash out)
- Make custom knock sensor bolts.
- Finish turbo manifold mods.
- Make intercooler pipework.
- Finish LS coil bracket, install coils.
- Mod spark plug cables to suit LS coils.
- Mount Turbo OPR.
- Install wideband controller.
- Install new fuel pump, upgrade wiring, move fuse and relay to boot, make / buy a relay / power distribution box in boot.
- Install body gauge.
- Engine back in.
- Swap auto for manual shifter.
- Clutch and flywheel install. (New bolts?)
- Install T5 transmission and make wiring.
- Flex Fuel Sensor.
- Blow of valve.
- More wires and connectors.
- Intake air temp sensor.
- AN4 aluminium hard line.
- Flywheel bolts. (Lost mine in the chaos)
- Cam and Crank sensor - 5V or 12V? 5v yeah?
- Engine light wire comes from PCM? Runs across under the dash?
