the climate control only works sometimes by that im mean if you start the car and the the display might not come straight on even if you play around with the controls then after a few minutes it may start all of a sudden or may not come on at all.
by the way when it works the aircon and everything works the way it should all speeds etc until you stop the car then it could start all over again or it may just work the way it should
any help would be great
thanks
thanks
