VS Commodore over cranking?
Wombles
Cars cost too much.
Pull the fuse when it's running. Mine doesn't crank at all when that fuse is pulled
Wombles
Cars cost too much.
Just be careful with the fuel lines as well. The usual.
PlenumBiscuit
VY Commodore
i put a couple of nice fat juicy earth cables onto my battery and it helped the startup speed....
# one from negative to body (replace the current pencil thin cable with a big fat heavy lug)
# and another from negative to engine (where heater bolt is that currently has an earth ring bolted)
started with a click of a finger. also clean up battery terminals even put new ones on
AlexVSII
Lithgow, NSW
1996 Holden VS Commodore S, 3.8 n/a
I'll second that, if after all the obvious things, earth cables are what I would be checking. I had mine go and originally thought it was a $300 starter motor. Was earth cables worth substantially less...
Sent from my XT910 using Tapatalk 4 Beta
velo
Tas
2016 VF SS - Black Edition
Just an update on this guys, today I had the chance to replace the fuel injectors and fuel pressure regulator with brand new items and also put in a new fuel filter and the starting problems are gone. Fires straight away now.
Cheers to everyone that helped :)
