vs exec dome light upgrade
A
AKII1R
Guest
i bought a dome light from the wreckers today(with the map lights),
wired it up and the noramal dome light works, but the map lights dont. globes ok... any ideas?? i have no idea about electronics but only a positive wire runs 2 the map lights?.
cheers
hispeedvp
VP SS Ute
W.A
VP Group A Ute
that cant be right (can it?) the map globes must have a posative and negative to work
Patrio7
3Y3 K4N 5P33K 1337.
Perth, Como
'96 S1 VS Exec
earth? maybe the map lights need a constnat 12v, try opening your door and see if the maplights come on
A
AKII1R
Guest
yeh thats wat i thought... i'll check the others 2moro when i take dis 1 bak.
kopper69
VRII Acclaim
An electric circuit needs to be a full loop from positive to negative to operate. The electricity will only pass through the bulb if it has somewhere to go. You need the 12v going into it and the earth connected to the other end (in laymans terms)
R
rattattack1313
Guest
Try it mate...just have a spare fuse or 2 handy......
markovr
62
northside brisbane
youtu.be
07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
One of the attachment screws goes through a copper strap that makes the path to earth ...you dont need the door open.The contact to the bulbs is the most likely problem either dirty or not making at all if the bulbs are ok.
jafo
lurker since 2003
59
adelaide
1999 wh statesman
bend the copper lugs in map reading light bit as they seem to squash in over time and need bending out a bit to make contact and chech the wiring erth is the sound of your problem like everyone else has said
A
AKII1R
Guest
thanks 4 the help guys. it was a faulty set up, wreckers gave me a new1 works a treat
cheers
