baroofy
- Feb 21, 2009
- 22
- 0
- 1
- vs equip
i have just replaced the wire from the alt. to the battery and feed to the fusable links. the insulation at the fusable link was melted. i had to replace the fusable link holder as well as all the plastic around the main feed was burnt and melted. is this a common problem?
i put a tong meter on the feed to the fusable link. it was drawing 15amps with just the engine running. with everything turned on (high beam head lights, demister, engine cooling fan,air con fan etc) i was getting 80 amps. is this normal, as the bolt in fuse is only rated to 60 amps.
thanks
thanks
