vs ss fault Code 33 - Manifold Absolute Pressure Sensor (MAP) - Voltage Too High
dano vs ss
burton
88 vl turbo
hey guys i recently changed my headgasket and after putting the engine back together i have this code and its pissing me off cause i cant figure out what it is exactly can some one please help me ??
Brett_jjj
Tamworth NSW
vs commodore
Check the MAP sensor wiring and vacuum hose to make sure theyre all connected properly.
dano vs ss
burton
88 vl turbo
i checked all the vacuum lines and all seem to be ok and connected properly the map sensor plug wires are ok no rust/corrosion and i plug it back in ??? what else couild it be cheers
Brett_jjj
Tamworth NSW
vs commodore
The VR/VS V6/V8 workshop manual says to check the MAP sensor, you connect 12 volt power to MAP sensor terminal C. Then check the voltage reading between MAP sensor connectors A and B. The reading should be between 3 volts to 5.5 volts. The voltage should drop as vacuum is applied to the snesor, if it doesnt drop , the sensor needs replacing. Im not too sure which terminals are A, B and C on the MAP sensor plug.
