pma9193
- Oct 27, 2013
- 5
- 0
- 0
- Location
- Perth
- VS Statesman LS1
hi first post here, i have a 96 statesman that has had a ls1 put in it.. it has a t350 beefed up g/box, but ive had issues with it cutting out (literally as if some one has turned the engine off), but starts and runs fine after. the ls1 has a mild cam, exhaust and mafless tune
it used to happen every once and a while and only once in a driving session. but recently in mornings on way to work as im driving along it would try to cut out or would cut out but save it self from dying. this would usually happen when the engine was still abit cold. i used to just let it idle for 5 or so minutes in the morning and it would usually be fine after that.
i took it to a mechanic and they recommended a performance shop as it may be a tuning issue. conversion was done at street torque in perth, i decided to take it to wa performance, the bloke had a quick look at some of the settings and noticed alot was incorrect. he dyno'd it a few times but the engine wouldnt cut out and it ran fine (WTF!). i got him to re-tune it anyway and replace 2 o2 sensors that were f***ed.
he did say that he noticed the heater circuit for the o2s had wired up be we both didnt think it would cause cutting out.
it was fine for about aweek after it got tuned but then the same process repeated. would just cut out once every now and then, and then would cut out and save it self while actually driving, and now when i go to when i go to warm the engine up in the morning i cuts out. like literally shuts off
then it will start up fine and cut out again. I repeat this sometimes twice or sometimes 10 times before it runs properly. sometimes when it cuts out after idling it does run a bit rough, but the evens out. (or cuts out)
im hoping that now it cuts out at idle aswell it may be easyer to troubleshoot! its such a pain in the ass. sometimes it runs fine straight away, or it dies, or runs rough then dies, or runs rough then fine
anyone got any ideas or similar experience of what may be going on here, im completley stumped dont even know where to start!!
cheers guys!
cheers guys!
