So if there black what does that mean?Pull the plugs tomorrow and see if any are black. They should all be white.
The oil is still good ill give that a go and see what happens would it make it a bit easier if I put some videos up of it idling and it reving and of normal drivingThen you have extremely rich running, burning oil or a problem with the spark. Just pulled the O2 plug first and see what happens. Then pull the plugs and check. Considering it run ok for a bit suggests to me the plugs are now fouled.
From what l've read on this site (jc) when extractors are new they will ruin o2 sensors. The new extractors are coated with something (l can't remember what). Anyway it ruins the o2 sensor(s).Got brand new pacemaker extractors
Right i did what old mate said and unplug the 02 sensors separately and then I left both unplugged and the car ran the exact same so does that mean there shot its running rough as btwFrom what l've read on this site (jc) when extractors are new they will ruin o2 sensors. The new extractors are coated with something (l can't remember what). Anyway it ruins the o2 sensor(s).
It will run rich too. Over fueling?
Try replacing the o2 sensor(s)?
I know vt v6 have 2 o2 sensors. I don't know if vs s3 have 1 or 2 02 sensors?
Anyway good luck with getting it running properly.
VS has 2 sensors, one on each side. The VZ has extra sensors before and after catalytic converter.I know vt v6 have 2 o2 sensors. I don't know if vs s3 have 1 or 2 02 sensors?
We are talking ecotecs not alloytecs.VS has 2 sensors, one on each side. The VZ has extra sensors before and after catalytic converter.
