Well known to suffer heat soak issue.
I know it's pretty well accepted that both the V8 and L67 CAIs suffer from heat soak when standing idle for long periods of time, and it can be felt that they get very hot if you're running the car at slow speeds for a long time, as might be encountered in stop/start traffic, but has anyone done any data logging of the what the heat soak is like when moving along at highway speeds? I would hazard a guess that the improved flow of air caused by the ram air effect into the front of the car, both into the intake itself and across the radiator would probably improve the heat soak issue, but how much it if it does happen at all I can't comment on. I had a L67 intake lying around that I put on, it didn't make the car faster, but it didn't make the car slower either, so while I wouldn't go out of my way to buy one, if you have one lying around or can obtain one cheaply, might as well put it on, can always take it off later if you want.
It's also worth noting that cold air isn't universally "good" and hot air isn't universally "bad". Hot air intakes are actually a thing that exist, warmer air can improve fuel economy and colder air can decrease fuel economy. Both have their own properties and affect the operation of an engine in different ways, with different side effects.
