VT Drive Belt Tensioner Replacement
chris852
I am trying to replace the tensioner in my 99 VT - I can't find the instructions in the Ellery manual. Could anyone post instructions to remove the drive belt tensioner?
Thanks.
Hot-Rod
SuPaFlY -LiV3 Surviv3 Di3
Oz
forums.justcommodores.com.au
VX Commodore Series 2
To Remove Tensioner
1. Disconnect battery earth lead.
2. Remove four nuts securing engine dress cover.
3. Using a 15 mm ring spanner on drive belt tensioner pulley pivot bolt, rotate tensioner pulley assembly anti-clockwise and remove drive belt from water pump pulley. Release tensioner pulley assembly and remove drive belt from remaining drive pulleys.
4.Remove radiator cap to release any cooling system pressure.
5.Remove generator assembly, (Alternator)
6. Remove nuts and powertrain wiring harness earth lead from tensioner bracket lower attaching studs.
7. Loosen hose clamp and remove heater outlet hose from heater outlet pipe connection.
8. Remove water inlet tube assembly.
9. Remove studs securing heater outlet pipe and drive belt tensioner assembly, pull heater outlet pipe out from inlet manifold connection and remove drive belt tensioner assembly.
vxcalais_01
VX Calais 3.8
very poor design unfortunately, you will also need a new rubber red oring for when putting back the heater pipe. THen you need to top up and bleed the system all over again.
Fr3ak+--
Closed On Monday
Kingswood, Nsw
Vt Exec 5 Speed
i did this today but i cannot get the heater pipe to stop leaking.. i replaced the oring but it still wont stop leaking.. anyone know how to fix?
Mr Jason Dennison
Melbourne Australia
Vt Calais 98
To Remove Tensioner
Mr Jason Dennison
Melbourne Australia
Vt Calais 98
Thank u 4 your help as im changing my tension peice also..I needed to know if it was anti or clockwise!! Now i know.cheers man..Keep on burning that rubber!!.Jaydee
vr304
Auckland, New Zealand
2007 ssv manual
i did this today but i cannot get the heater pipe to stop leaking.. i replaced the oring but it still wont stop leaking.. anyone know how to fix?[
Hose clamps probably need re tightening
NeddyBear
Veteran Mountain Biker
Rubyvale, Qld
2004 2.5L Subaru Outback
One tip, don't use the O ring that comes with the Tensioner. Go buy a genuine Holden one, I used the one with the Tensioner and it pissed coolant.
moriati
vx s
hi guys i did mine today i bought the 0 rings from holden as the gentleman said in the above post i fitted everything correctly but i forgot to lubricate the 0 rings and apparently as i inserted the inlet pipe the 0 ring must have got caught somewhere along the way and it got cut when i filled up the radiator with coolant it started pissing out from the inlet pipe lucky i had the 0 ring that came with the tensioner and replaced it it worked fine but lucky i went to holden to buy the other two 0 rings.. so if your doing this make sure you lubricate the 0 rings with some vasalline it works fine and with a clean rag clean the inside of the the holes where the inlet and outlet heater pipes go....
moriati
vx s
moriati
vx s
